Introdução
Is your computer making loud noises and taking longer than normal to boot? Consider using this guide to replace the cooling fan in your device.
O que você precisa
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
Quase terminado!
Conclusão
