1. Make sure your device is powered off before beginning this guide. Place your device on your workspace, screen facing down. Take the Spudger and use the pointed end to catch the latch below the battery. Drag the latch to the right until the battery detaches from the body of the device.
    • Make sure your device is powered off before beginning this guide.
    • Place your device on your workspace, screen facing down. Take the Spudger and use the pointed end to catch the latch below the battery. Drag the latch to the right until the battery detaches from the body of the device.
  2. Pull the battery out, making sure to pull the battery parallel to the device.
    • Pull the battery out, making sure to pull the battery parallel to the device.
  3. Ensure device is powered off and unplugged from a power source. Place the device upside down.
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  4. Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  5. Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  6. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive. Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  8. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing. Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
  9. Prior to completing the steps laid out in this guide, it is imperative that the user remove the battery and hard drive via the battery and hard drive replacement guide steps available. Use a PH0 Philips head screwdriver to remove the remaining 9.0 mm screws on the back of the device which should be sixteen screw in total.
    • Prior to completing the steps laid out in this guide, it is imperative that the user remove the battery and hard drive via the battery and hard drive replacement guide steps available.
    • Use a PH0 Philips head screwdriver to remove the remaining 9.0 mm screws on the back of the device which should be sixteen screw in total.
  10. Use a plastic opening tool to pry open the sides of the laptop base starting closest to the hinges.
    • Use a plastic opening tool to pry open the sides of the laptop base starting closest to the hinges.
  11. After prying the keyboard unit off of the base, Lift the white, hinged covers connected to the three ribbons shown and pull gently to disconnect. When putting the laptop back together, lift the hinged covers and connect the ribbons before dropping the hinged covers back down. When putting the laptop back together, lift the hinged covers and connect the ribbons before dropping the hinged covers back down.
    • After prying the keyboard unit off of the base, Lift the white, hinged covers connected to the three ribbons shown and pull gently to disconnect.
    • When putting the laptop back together, lift the hinged covers and connect the ribbons before dropping the hinged covers back down.
  12. Disconnect the wires that are connected to the Wireless Lan chip. Use the PH0 Philips head screwdriver to remove the 9.0 mm screw that is connected to the Wireless Lan chip in the right upper corner. Then remove the CPU by angling it upwards and pulling it towards the laptop screen. Use the PH0 Philips head screwdriver to remove the 9.0 mm screw that is connected to the Wireless Lan chip in the right upper corner. Then remove the CPU by angling it upwards and pulling it towards the laptop screen.
    • Disconnect the wires that are connected to the Wireless Lan chip.
    • Use the PH0 Philips head screwdriver to remove the 9.0 mm screw that is connected to the Wireless Lan chip in the right upper corner. Then remove the CPU by angling it upwards and pulling it towards the laptop screen.
  13. Disconnect the remaining wires indicated. The flat head of the spudger tool may be helpful in removing these wires without damaging the device. The flat head of the spudger tool may be helpful in removing these wires without damaging the device.
    • Disconnect the remaining wires indicated.
    • The flat head of the spudger tool may be helpful in removing these wires without damaging the device.
  14. Use a PH0 Philips head screwdriver to remove the 9.0 mm screw connected to the CPU Fan. Once the screw is out of the CPU Fan, then remove the two other 9.0 mm screws indicated. Once the screw is out of the CPU Fan, then remove the two other 9.0 mm screws indicated.
    • Use a PH0 Philips head screwdriver to remove the 9.0 mm screw connected to the CPU Fan.
    • Once the screw is out of the CPU Fan, then remove the two other 9.0 mm screws indicated.
  15. This step requires the most caution. The CPU fan will remain attached to the motherboard. Lift the motherboard up and out of the casing and pull it away from the screen in order to partially detach it from the laptop. Turn over the motherboard and disconnect the wire labeled.
    • This step requires the most caution. The CPU fan will remain attached to the motherboard.
    • Lift the motherboard up and out of the casing and pull it away from the screen in order to partially detach it from the laptop.
    • Turn over the motherboard and disconnect the wire labeled.
    • Some of the motherboard is connected to the battery so be extra careful from detaching the motherboard from the device.
  16. Use the PH0 screwdriver to unscrew the three 9.0 mm screws that are connected to the CPU Fan. At this point of the process, the CPU Fan should be detached from the device. At this point of the process, the CPU Fan should be detached from the device.
    • Use the PH0 screwdriver to unscrew the three 9.0 mm screws that are connected to the CPU Fan.
    • At this point of the process, the CPU Fan should be detached from the device.
Conclusão
Jared Lotfi
283 reputação
2 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Todo: 81
