Ir para o conteúdo principal
Gateway MS2370 Screen Replacement
O que você precisa
  1. Gateway MS2370 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: passo 2, imagem 1 %32
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: passo 3, imagem 1 %32
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: passo 5, imagem 1 %32 Gateway MS2370 Screen Replacement: passo 5, imagem 2 %32
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: passo 6, imagem 1 %32
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: passo 7, imagem 1 %32
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: passo 8, imagem 1 %32
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: passo 9, imagem 1 %32 Gateway MS2370 Screen Replacement: passo 9, imagem 2 %32 Gateway MS2370 Screen Replacement: passo 9, imagem 3 %32
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: passo 10, imagem 1 %32 Gateway MS2370 Screen Replacement: passo 10, imagem 2 %32
    • Slowly remove the screen from the laptop.
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 802
