Ir para o conteúdo principal
Gateway MS2370 Keyboard Replacement
O que você precisa
  1. Gateway MS2370 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Keyboard Replacement: passo 2, imagem 1 %32
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
  5. Gateway MS2370 Keyboard Replacement: passo 5, imagem 1 %32
    • Carefully lift the keyboard molding out.
  6. Gateway MS2370 Keyboard Replacement: passo 6, imagem 1 %32
    • Use the plastic spudger again to pry the keyboard tabs from the laptop.
  7. Gateway MS2370 Keyboard Replacement: passo 7, imagem 1 %32
    • Slowly lift the keyboard from the laptop.
  8. Gateway MS2370 Keyboard Replacement: passo 8, imagem 1 %32 Gateway MS2370 Keyboard Replacement: passo 8, imagem 2 %32
    • Carefully unplug the ribbon cable attached to the motherboard.
    • The ribbon cable is extremely delicate, handle with care
  9. Gateway MS2370 Keyboard Replacement: passo 9, imagem 1 %32
    • Lift and remove the keyboard from the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 913
