Ir para o conteúdo principal
Gateway MS2285 Hard Drive Replacement
O que você precisa
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: passo 1, imagem 1 %32
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: passo 2, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: passo 2, imagem 2 %32
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: passo 3, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Release The Battery: passo 3, imagem 2 %32
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: passo 4, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Remove The Battery: passo 4, imagem 2 %32
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: passo 5, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: passo 5, imagem 2 %32
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: passo 6, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: passo 6, imagem 2 %32 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: passo 6, imagem 3 %32
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: passo 7, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: passo 7, imagem 2 %32
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: passo 8, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: passo 8, imagem 2 %32
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: passo 9, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: passo 9, imagem 2 %32 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: passo 9, imagem 3 %32
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: passo 10, imagem 1 %32 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: passo 10, imagem 2 %32
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
Conclusão
Uma outra pessoa concluiu este guia.
Chris mello
Membro desde: 10/22/14
331 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 3,754
