Ir para o conteúdo principal
Gateway MS2285 Battery Replacement
  1. Gateway MS2285 Battery Replacement, Turn Laptop Over: passo 1, imagem 1 %32
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Battery Replacement, Unlock The Battery: passo 2, imagem 1 %32 Gateway MS2285 Battery Replacement, Unlock The Battery: passo 2, imagem 2 %32
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Battery Replacement, Release The Battery: passo 3, imagem 1 %32 Gateway MS2285 Battery Replacement, Release The Battery: passo 3, imagem 2 %32
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Battery Replacement, Remove The Battery: passo 4, imagem 1 %32 Gateway MS2285 Battery Replacement, Remove The Battery: passo 4, imagem 2 %32
    • Grasp the battery's raised end and lift upwards.
Conclusão
Chris mello
Membro desde: 10/22/14
331 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,260
