Ir para o conteúdo principal
Gateway MD2614u Processor Replacement
O que você precisa
  1. Gateway MD2614u Processor Replacement, Back Cover: passo 1, imagem 1 %32
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: passo 2, imagem 1 %32
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: passo 3, imagem 1 %32
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: passo 4, imagem 1 %32
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: passo 5, imagem 1 %32
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: passo 6, imagem 1 %32
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: passo 7, imagem 1 %32
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: passo 9, imagem 1 %32
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
Conclusão
Toni Pipes
Membro desde: 10/05/10
333 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-31, Regan Fall 2010 Membro de Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
Membros da 4
Autoria de 14 guias
Um comentário
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 7,148
