Ir para o conteúdo principal
Gateway MD2614u Battery Replacement
  1. Gateway MD2614u Battery Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
  2. Gateway MD2614u Battery Replacement: passo 2, imagem 1 %32
    • Slide and hold the battery release lock to the left.
  3. Gateway MD2614u Battery Replacement: passo 3, imagem 1 %32
    • Pull the battery away from the laptop.
  4. Gateway MD2614u Battery Replacement: passo 4, imagem 1 %32
    • Insert the new battery into the slot.
Conclusão
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
Membro desde: 10/05/10
333 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-31, Regan Fall 2010 Membro de Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 3,923
