Ir para o conteúdo principal
Gateway MA6 Laptop RAM Replacement
O que você precisa
  1. Gateway MA6 Laptop RAM Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop RAM Replacement: passo 2, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 2, imagem 2 %32 Gateway MA6 Laptop RAM Replacement: passo 2, imagem 3 %32
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop RAM Replacement, RAM: passo 3, imagem 1 %32 Gateway MA6 Laptop RAM Replacement, RAM: passo 3, imagem 2 %32
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  4. Gateway MA6 Laptop RAM Replacement: passo 4, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 4, imagem 2 %32
    • Pull upwards on the top of the back cover to remove it.
  5. Gateway MA6 Laptop RAM Replacement: passo 5, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 5, imagem 2 %32 Gateway MA6 Laptop RAM Replacement: passo 5, imagem 3 %32
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
  6. Gateway MA6 Laptop RAM Replacement: passo 6, imagem 1 %32 Gateway MA6 Laptop RAM Replacement: passo 6, imagem 2 %32
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
Conclusão
Chris Naughton
Membro desde: 04/07/14
705 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-2, Forte Spring 2014 Membro de Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 1,204
