Ir para o conteúdo principal
Gateway M-2626u RAM Replacement
O que você precisa
  1. Gateway M-2626u RAM  Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: passo 2, imagem 1 %32 Gateway M-2626u RAM  Replacement: passo 2, imagem 2 %32 Gateway M-2626u RAM  Replacement: passo 2, imagem 3 %32
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: passo 3, imagem 1 %32 Gateway M-2626u RAM  Replacement, Back Panel: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: passo 4, imagem 1 %32 Gateway M-2626u RAM  Replacement: passo 4, imagem 2 %32
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: passo 5, imagem 1 %32
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: passo 6, imagem 1 %32 Gateway M-2626u RAM  Replacement: passo 6, imagem 2 %32
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
Conclusão
Tanya Jain
Membro desde: 03/19/18
317 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S3-G2, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G2, Peak Spring 2018
UMASSD-PEAK-S18S3G2
Membros da 2
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 164
