Introdução
If your laptop keeps crashing or is running slow, then consider replacing the RAM of your device using this guide here.
O que você precisa
Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Quase terminado!
Conclusão
