Ir para o conteúdo principal
Gateway M-2626u Hard Drive Replacement
O que você precisa
  1. Gateway M-2626u Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: passo 2, imagem 1 %32 Gateway M-2626u Hard Drive Replacement: passo 2, imagem 2 %32 Gateway M-2626u Hard Drive Replacement: passo 2, imagem 3 %32
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Gateway M-2626u Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: passo 5, imagem 1 %32 Gateway M-2626u Hard Drive Replacement: passo 5, imagem 2 %32 Gateway M-2626u Hard Drive Replacement: passo 5, imagem 3 %32
    • Using your hands, carefully pull out the hard drive from its compartment.
Conclusão
Femi
Membro desde: 04/06/18
219 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Membro de UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 221
