Ir para o conteúdo principal
Gateway M-2626u CPU Replacement
O que você precisa
  1. Gateway M-2626u CPU Replacement, Back Panel: passo 1, imagem 1 %32 Gateway M-2626u CPU Replacement, Back Panel: passo 1, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Gateway M-2626u CPU Replacement: passo 2, imagem 1 %32 Gateway M-2626u CPU Replacement: passo 2, imagem 2 %32
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. Gateway M-2626u CPU Replacement, CPU Fan: passo 3, imagem 1 %32 Gateway M-2626u CPU Replacement, CPU Fan: passo 3, imagem 2 %32
    • Remove the header by pulling on it with two fingers.
  4. Gateway M-2626u CPU Replacement: passo 4, imagem 1 %32
    • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
  5. Gateway M-2626u CPU Replacement: passo 5, imagem 1 %32
    • Remove the fan by moving it to the side and lifting it out of the computer.
  6. Gateway M-2626u CPU Replacement, CPU: passo 6, imagem 1 %32
    • Once the fan is removed, locate the CPU.
    • Rotate the plastic knob using a flat head screw driver as depicted in this image
  7. Gateway M-2626u CPU Replacement: passo 7, imagem 1 %32
    • Lift and remove the CPU from the mother board socket.
Conclusão
Armani Tayeh
Membro desde: 03/19/18
432 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G2, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G2, Peak Spring 2018
UMASSD-PEAK-S18S3G2
Membros da 2
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 238
