Introdução
If your computer is failing due to old age and you think you need a CPU replacement, follow this guide to help replace it.
O que você precisa
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Once the fan is removed, locate the CPU.
Rotate the plastic knob using a flat head screw driver as depicted in this image
Quase terminado!
Conclusão
