Introdução
If you need to have access to the inner workings of your laptop in order to replace some parts, this guide will help you to remove the panels to access them.
Peças
Não são necessárias peças.
  1. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
Conclusão
Armani Tayeh
411 reputação
4 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Todo: 32
