Ir para o conteúdo principal
Gateway M-2626u Battery Replacement
  1. Gateway M-2626u  Battery Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u  Battery Replacement: passo 2, imagem 1 %32 Gateway M-2626u  Battery Replacement: passo 2, imagem 2 %32 Gateway M-2626u  Battery Replacement: passo 2, imagem 3 %32
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
Conclusão
Tanya Jain
Membro desde: 03/19/18
317 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S3-G2, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G2, Peak Spring 2018
UMASSD-PEAK-S18S3G2
Membros da 2
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 232
