Ir para o conteúdo principal
Gateway LT41P10u Track Pad Replacement
O que você precisa
  1. Gateway LT41P10u Track Pad Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Track Pad Replacement: passo 2, imagem 1 %32
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Track Pad Replacement: passo 3, imagem 1 %32
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  4. Gateway LT41P10u Track Pad Replacement, Keyboard: passo 4, imagem 1 %32 Gateway LT41P10u Track Pad Replacement, Keyboard: passo 4, imagem 2 %32
    • Once the battery is removed, flip the laptop over and open it up so you can see the keyboard.
    • Underneath the f4, f8, and f12 keys there are indents (see the second image) to fit a spudger or plastic opening tool to pop the keyboard off.
    • Once you find an indent with your spudger, carefully move it so the top of the keyboard comes away from the rest of the computer, followed by the bottom of the keyboard.
  5. Gateway LT41P10u Track Pad Replacement: passo 5, imagem 1 %32
    • Once you pull the keyboard off, you will see a ribbon wire connecting the keyboard to the rest of the laptop.
    • To detach the keyboard from the rest of the computer, you have to unlock the ribbon by pulling up on the small black lock keeping the ribbon from being removed. You won't have to pull very hard, so be gentle to avoid damaging it.
    • Once the ribbon is disconnected from the computer, you are able to pull the ribbon out from underneath the lock, and then pull the keyboard away.
  6. Gateway LT41P10u Track Pad Replacement, Track Pad: passo 6, imagem 1 %32 Gateway LT41P10u Track Pad Replacement, Track Pad: passo 6, imagem 2 %32 Gateway LT41P10u Track Pad Replacement, Track Pad: passo 6, imagem 3 %32
    • Remove screws from back plate using phillips screwdriver.
    • After removing the back screws use same phillips screwdriver to remove all screws from top plate. (see images 2 and 3, bottom screws from image 2 overlap with top screws from image 3.)
    • Once all screws are removed from top and bottom plates disconnect cable ribbon indicated by a red arrow in images 2 and 3.
  7. Gateway LT41P10u Track Pad Replacement: passo 7, imagem 1 %32 Gateway LT41P10u Track Pad Replacement: passo 7, imagem 2 %32
    • Carefully remove plate.
    • Track pad is located on the under side of the plate indicated by image 2.
    • To replace track pad you must replace the entire plate. (Track pad is permanently attached this plate.)
Conclusão
Michael Smith
Membro desde: 10/19/17
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Membro de UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 154
