Ir para o conteúdo principal
Gateway LT41P10u Battery Replacement
  1. Gateway LT41P10u Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Battery Replacement: passo 2, imagem 1 %32
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Battery Replacement: passo 3, imagem 1 %32
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
Conclusão
To put the battery back, just slide it back into its slot and make sure that both locking tabs are locked.
Michael Smith
Membro desde: 10/19/17
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Membro de UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 274
