Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
The RAM can be replaced if you have a Phillips #0 screwdriver.
Peças
Nenhum componente especificado.
  1. Unlock the tab located in the top left corner of the netbook. The red tab indicated that the battery has been properly unlocked. Remove the battery.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. The RAM is located under this cover.
    • The RAM is located under this cover.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place. Use a plastic opening tool to remove the cover. Use a plastic opening tool to remove the cover.
    • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
    • Use a plastic opening tool to remove the cover.
  5. Unlock the RAM by pinching the metal clamps that keep the RAM in place. Remove the RAM while the metal clamps are disengaged.
    • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
    • Remove the RAM while the metal clamps are disengaged.
Conclusão
Lydia Benjock
Membro desde: 18-10-2013
1.189 Reputação
10 Guias de autoria
equipe
Clemson, Team 14-3, Benson Fall 2013 Membro de Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Membros
22 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,702
