Ir para o conteúdo principal
Gateway ID49C07U Screen Replacement
O que você precisa
  1. Gateway ID49C07U Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: passo 2, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 2, imagem 2 %32
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: passo 3, imagem 1 %32
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: passo 4, imagem 1 %32
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: passo 5, imagem 1 %32
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: passo 6, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 6, imagem 2 %32
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: passo 7, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 7, imagem 2 %32
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: passo 8, imagem 1 %32
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: passo 9, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 9, imagem 2 %32 Gateway ID49C07U Screen Replacement: passo 9, imagem 3 %32
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: passo 10, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 10, imagem 2 %32 Gateway ID49C07U Screen Replacement: passo 10, imagem 3 %32
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: passo 11, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 11, imagem 2 %32
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: passo 12, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: passo 13, imagem 1 %32 Gateway ID49C07U Screen Replacement: passo 13, imagem 2 %32
    • Hold the tape back with one hand and pull the connector out
Conclusão
Ryan Howlett
Membro desde: 03/06/17
267 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 315
