Ir para o conteúdo principal
Gateway ID49C07U DVD Drive Replacement
O que você precisa
  1. Gateway ID49C07U DVD Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U DVD Drive Replacement: passo 2, imagem 1 %32 Gateway ID49C07U DVD Drive Replacement: passo 2, imagem 2 %32
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U DVD Drive Replacement: passo 3, imagem 1 %32
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U DVD Drive Replacement: passo 4, imagem 1 %32
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U DVD Drive Replacement, DVD Drive: passo 5, imagem 1 %32
    • Locate screw towards the center of the device and unscrew it
  6. Gateway ID49C07U DVD Drive Replacement: passo 6, imagem 1 %32 Gateway ID49C07U DVD Drive Replacement: passo 6, imagem 2 %32 Gateway ID49C07U DVD Drive Replacement: passo 6, imagem 3 %32
    • Use a metal spudger to pry off the DVD drive.
    • Once loosened, use your hand to pull the DVD drive out.
Conclusão
Patrick McGrail
Membro desde: 03/19/17
445 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 261
