Ir para o conteúdo principal
Gateway GWTC116-2BL Display Replacement
O que você precisa
  1. Gateway GWTC116-2BL Display Replacement, Back Panel: passo 1, imagem 1 %32
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Display Replacement: passo 2, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 2, imagem 2 %32
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Display Replacement, Battery: passo 3, imagem 1 %32
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Display Replacement: passo 4, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 4, imagem 2 %32
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Display Replacement: passo 5, imagem 1 %32
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Display Replacement, Motherboard: passo 6, imagem 1 %32
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
  7. Gateway GWTC116-2BL Display Replacement: passo 7, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 7, imagem 2 %32
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
  8. Gateway GWTC116-2BL Display Replacement: passo 8, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 8, imagem 2 %32
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
  9. Gateway GWTC116-2BL Display Replacement: passo 9, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 9, imagem 2 %32 Gateway GWTC116-2BL Display Replacement: passo 9, imagem 3 %32
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
  10. Gateway GWTC116-2BL Display Replacement: passo 10, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 10, imagem 2 %32
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
  11. Gateway GWTC116-2BL Display Replacement: passo 11, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 11, imagem 2 %32
    • Peel off the black piece of tape covering the display cable.
  12. Gateway GWTC116-2BL Display Replacement: passo 12, imagem 1 %32 Gateway GWTC116-2BL Display Replacement: passo 12, imagem 2 %32
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
  13. Gateway GWTC116-2BL Display Replacement: passo 13, imagem 1 %32
    • Remove the motherboard from the device.
  14. Gateway GWTC116-2BL Display Replacement, Display: passo 14, imagem 1 %32
    • Remove seven 3.0 mm Phillips #00 screws from the laptop.
  15. Gateway GWTC116-2BL Display Replacement: passo 15, imagem 1 %32
    • Applying some force, use your hands to pry the display of the laptop away from the base.
Conclusão
Kailey Sousa
Membro desde: 03/22/24
459 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 6-2, Botvin Spring 2024 Membro de UMass Dartmouth, Team 6-2, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 45
Duração total: 113
