Ir para o conteúdo principal
Gateway GWTC116-2BL Daughterboard Replacement
O que você precisa
  1. Gateway GWTC116-2BL Daughterboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Daughterboard Replacement: passo 2, imagem 1 %32 Gateway GWTC116-2BL Daughterboard Replacement: passo 2, imagem 2 %32
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Daughterboard Replacement, Battery: passo 3, imagem 1 %32
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Daughterboard Replacement: passo 4, imagem 1 %32 Gateway GWTC116-2BL Daughterboard Replacement: passo 4, imagem 2 %32
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Daughterboard Replacement: passo 5, imagem 1 %32
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: passo 6, imagem 1 %32 Gateway GWTC116-2BL Daughterboard Replacement, Daughterboard: passo 6, imagem 2 %32
    • Peel off the yellow piece of tape that is placed over the daughterboard.
  7. Gateway GWTC116-2BL Daughterboard Replacement: passo 7, imagem 1 %32
    • Remove the three 3.0 mm Phillips #00 screws.
  8. Gateway GWTC116-2BL Daughterboard Replacement: passo 8, imagem 1 %32 Gateway GWTC116-2BL Daughterboard Replacement: passo 8, imagem 2 %32
    • Flick open the bracket that connects the motherboard and daughterboard.
    • Remove the connector strip.
  9. Gateway GWTC116-2BL Daughterboard Replacement: passo 9, imagem 1 %32
    • Remove the daughterboard from the base of the computer.
Conclusão
Kailey Sousa
Membro desde: 03/22/24
459 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 6-2, Botvin Spring 2024 Membro de UMass Dartmouth, Team 6-2, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 69
