Introdução
removal of the system board
O que você precisa
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Slide the release and push the button to eject the drive.
Remove the drive.
Unscrew 1 captive screw holding hard drive cover on.
slide hard drive to the right and remove.
for detailed pictures and info go to Gateway Support
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Remove the five screws with a Phillips #0 screwdriver.
Lift the hinge covers along the outer edges with the spudger until they are released.
Unscrew the four captive screws.
Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
