Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Remove the battery cover using the tab on the right side.
Take the battery out with your index finger.
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Remove the five screws with a Phillips #0 screwdriver.
Lift the hinge covers along the outer edges with the spudger until they are released.
Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
Remove the cable by gently pulling it out while holding down the LCD.
