Pular para o conteúdo principal
Introdução
Removal of LCD display
Peças
Nenhum componente especificado.
  1. Flip the laptop over. Slide the battery release tab to the right.
    • Flip the laptop over. Slide the battery release tab to the right.
  2. Lift the battery out.
    • Lift the battery out.
  3. Insert spudger between sysrq and ins keys.
    • Insert spudger between sysrq and ins keys.
    • Gently lift power button panel from the right to left.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  5. Remove 5 screws.
    • Remove 5 screws.
    • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
    • Remove hinge covers.
  6. Gently unplug LCD from system board.
    • Gently unplug LCD from system board.
  7. Remove 6 screws holding LCD to hinge.
    • Remove 6 screws holding LCD to hinge.
  8. Pull LCD away from case.
    • Pull LCD away from case.
Conclusão
Elizabeth Mazer
Membro desde: 14-10-2010
78 reputação
10 Guias de autoria
Equipe
Cal Poly, Team 20-10, Maness Fall 2010 Membro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Membros
22 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,706
