Ir para o conteúdo principal
Gateway 600YG2 CPU Replacement
O que você precisa
  1. Gateway 600YG2 CPU Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 CPU Replacement: passo 2, imagem 1 %32
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 CPU Replacement, Power Button Panel: passo 3, imagem 1 %32
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 CPU Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the 5 screws holding the keyboard in place.
  5. Gateway 600YG2 CPU Replacement: passo 5, imagem 1 %32 Gateway 600YG2 CPU Replacement: passo 5, imagem 2 %32
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Gateway 600YG2 CPU Replacement, System Fan: passo 6, imagem 1 %32 Gateway 600YG2 CPU Replacement, System Fan: passo 6, imagem 2 %32
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
  7. Gateway 600YG2 CPU Replacement, CPU: passo 7, imagem 1 %32
    • Turn screw 1/4 turn to the right.
    • When reinstalling ensure proper orientation the yellow arrow on CPU should be in upper left corner
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth Mazer
Membro desde: 10/14/10
78 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 20-10, Maness Fall 2010 Membro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
Membros da 3
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,968
