Ir para o conteúdo principal
Gateway 3545GZ Fan Replacement
O que você precisa
  1. Gateway 3545GZ Fan Replacement, Fan: passo 1, imagem 1 %32 Gateway 3545GZ Fan Replacement, Fan: passo 1, imagem 2 %32
    • Unscrew 14mm screws with Phillips screwdriver.
    • Unscrew 3mm screws with the same Phillips screwdriver.
    • Screws that are circled in red are 3mm; the screw circled in blue is 14mm
    • Remove the protective cover.
  2. Gateway 3545GZ Fan Replacement: passo 2, imagem 1 %32 Gateway 3545GZ Fan Replacement: passo 2, imagem 2 %32 Gateway 3545GZ Fan Replacement: passo 2, imagem 3 %32
    • Unscrew the four screws holding it in place with the same PH1 Phillips-Head screwdriver. They are numbered on the fan, 1,2,3,4.
    • The four screws are 12mm long, they also have a spring surrounding them.
    • Then carefully pull the cord connecting the fan to the notebook.
    • Insert your replacement fan, plug in its cord, screw it into place, and reattach the protective cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 209
