Ir para o conteúdo principal
Gas Grill Ceramic Briquettes Replacement
O que você precisa
  1. Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: passo 1, imagem 1 %32 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: passo 1, imagem 2 %32 Gas Grill Ceramic Briquettes Replacement, Remove Grill Plate: passo 1, imagem 3 %32
    • Carefully lift grill plate located above briquettes
    • Make sure the gas grill is off and the propane is turned off before removing the grill plate
  2. Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: passo 2, imagem 1 %32 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: passo 2, imagem 2 %32 Gas Grill Ceramic Briquettes Replacement, Remove Ceramic Briquette Casing Panel: passo 2, imagem 3 %32
    • Carefully remove entire ceramic briquette casing from above the stainless steel burner.
  3. Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: passo 3, imagem 1 %32 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: passo 3, imagem 2 %32 Gas Grill Ceramic Briquettes Replacement, Unscrew Briquette Casing: passo 3, imagem 3 %32
    • Locate the six screws located on top of the ceramic briquette casing and unscrew them using your phillips head screwdriver.
    • A small container is recommended to keep the screws together
  4. Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: passo 4, imagem 1 %32 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: passo 4, imagem 2 %32 Gas Grill Ceramic Briquettes Replacement, Unscrew Washers: passo 4, imagem 3 %32
    • Using your hands, gently unscrew washers from the back of the casing.
    • A small container is recommended to keep the washers together
  5. Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: passo 5, imagem 1 %32 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: passo 5, imagem 2 %32 Gas Grill Ceramic Briquettes Replacement, Separate Two Pieces: passo 5, imagem 3 %32
    • Separate the front and back metal casings surrounding the briquettes.
  6. Gas Grill Ceramic Briquettes Replacement, Remove Old Briquettes: passo 6, imagem 1 %32
    • Take out old and used briquettes and dispose of them. (They will probably be black and tarnished)
  7. Gas Grill Ceramic Briquettes Replacement, Replace With New Ones: passo 7, imagem 1 %32
    • Take 16 new ceramic briquettes out and carefully align them inside the casing.
    • Be sure to pay attention to where you place them, as some should be straight and some diagonal for the casing to close back correctly.
Conclusão
3 outras pessoas executaram este guia.
emma
Membro desde: 01/27/16
173 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 38
Duração total: 3,789
