Introdução
In GBB the magazine does most of the work so it is good to know how to work on it.
O que você precisa
If you have taken down the magazine this far you can start screwing the tubes and caps. Either end of the tube will work.
The o-ring can be a little crushed and still work effectively just make sure the the o-ring is evenly in position.
The pliers technique used in the disassemble can also be used to screw the tubes back on to the rest of assemble.
The tubes and caps need to tightly screwed down but not overly forced.
With the tubes and caps in place now is a good time check for leaks.
If your valves have been removed begin putting them into place.
Make sure that threads are line up and do not apply too much for to the valves.
As mentioned in the disassemble using the proper valve removal tools is always best but with care you can use standard tools as shown.
Once everything in place you can gas up the magazine. I recommend using a green gas can that is not at full pressure to save on gas if it turns out that there still is a leak. If the lower pressure gas does not leak try filling the magazine with a full can of gas to see if it can handle the higher pressure.
If your trying find where a leak is coming from you can use the silicone spray on hole magazine and look for the bubbles.
Take the bb follower and set into the top of the of the bb track.
Then take the spring and set it into position.
With the core of the magazines all re-assembled, hold the spring in place then slide it back into the outer shell.
Tap the flat section on the top to get the core into position.
If you took the bb retention piece out earlier or it came out mistake when unloading bb's this step will show you how to put it back.
Use a tool to hold back the spring. Once it's back grab the leg of the spring with needles nose pliers.
Then take the retention piece and slide it back into place.
