Ir para o conteúdo principal
Introdução
To remove the device from the wristband, no extra tools will be necessary. This guide will explain how to safely remove the device.
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band. Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
    • Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
Conclusão
James Hickey
Membro desde: 26/03/2018
290 Reputação
2 Guias de autoria
Equipe
IUPUI, Team S1-G2, Harley Spring 2018 Membro de IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 Membros
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 205
