Ir para o conteúdo principal
Introdução
This guide will explain how to replace the batteries of the Garmin vívofit 2 device. A Phillips #00 screwdriver and two replacement CR1632 Batteries will be needed. The process is straightforward and there are no hazards involved.
  1. Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band. Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
    • Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
  2. Remove the four 3.8mm Phillips #00 screws holding the device together.
    • Remove the four 3.8mm Phillips #00 screws holding the device together.
  3. With the screws removed from the device, take the cover off the top of the device, revealing the batteries inside.
    • With the screws removed from the device, take the cover off the top of the device, revealing the batteries inside.
  4. With the cover removed,  take out the two batteries currently in the device. Take note of which side of the battery is facing which way in the device. Battery removal can usually be accomplished with your fingers. If not, carefully use a nylon spudger to pull up one edge of the battery, allowing you to remove that battery.
    • With the cover removed, take out the two batteries currently in the device. Take note of which side of the battery is facing which way in the device. Battery removal can usually be accomplished with your fingers. If not, carefully use a nylon spudger to pull up one edge of the battery, allowing you to remove that battery.
Conclusão
Uma outra pessoa concluiu este guia.
James Hickey
Membro desde: 26/03/2018
290 Reputação
2 Guias de autoria
Equipe
IUPUI, Team S1-G2, Harley Spring 2018 Membro de IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 Membros
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 39
Duração total: 1,713
