Ir para o conteúdo principal
Garmin nuviCam LMTHD Motherboard Replacement
O que você precisa
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: passo 1, imagem 1 %32 Garmin nuviCam LMTHD Motherboard Replacement, Screen: passo 1, imagem 2 %32
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: passo 2, imagem 1 %32 Garmin nuviCam LMTHD Motherboard Replacement: passo 2, imagem 2 %32
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: passo 4, imagem 1 %32 Garmin nuviCam LMTHD Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: passo 6, imagem 1 %32
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: passo 7, imagem 1 %32
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: passo 9, imagem 1 %32
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: passo 10, imagem 1 %32 Garmin nuviCam LMTHD Motherboard Replacement: passo 10, imagem 2 %32
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: passo 11, imagem 1 %32 Garmin nuviCam LMTHD Motherboard Replacement: passo 11, imagem 2 %32
    • Lift motherboard out of device using plastic opening tools.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 655
