Ir para o conteúdo principal
Garmin nuviCam LMTHD Battery Replacement
O que você precisa
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: passo 1, imagem 1 %32 Garmin nuviCam LMTHD Battery Replacement, Screen: passo 1, imagem 2 %32
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Battery Replacement: passo 2, imagem 1 %32 Garmin nuviCam LMTHD Battery Replacement: passo 2, imagem 2 %32
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Battery Replacement: passo 4, imagem 1 %32 Garmin nuviCam LMTHD Battery Replacement: passo 4, imagem 2 %32
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: passo 5, imagem 1 %32
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: passo 6, imagem 1 %32
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: passo 7, imagem 1 %32
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: passo 8, imagem 1 %32
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
Conclusão
7 outras pessoas executaram este guia.
4 comentários
Where did you buy the battery? What is the voltage/current?
John Justin - Responder
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
Gary - Responder
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
guy.adamson - Responder
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
Zach - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 4,935
