Ir para o conteúdo principal
Garmin nuvi 2460 LMT Speaker Replacement
O que você precisa
  1. Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: passo 1, imagem 2 %32
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Speaker Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Speaker Replacement: passo 3, imagem 1 %32
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Speaker Replacement: passo 4, imagem 1 %32
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Speaker Replacement, Speaker: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift and separate the speaker connector cable using a pair of tweezers.
  6. Garmin nuvi 2460 LMT Speaker Replacement: passo 6, imagem 1 %32
    • Gently lift the speaker out of the back cover using a plastic opening tool.
    • Apply force as needed if there is glue holding the speaker in place.
Conclusão
Ricardo Audain
Membro desde: 09/07/16
671 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 6-4, Remmell Fall 2016 Membro de USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
Membros da 4
Autoria de 7 guias
Um comentário
Where do I get the parts for the garmin nuvi 2460? I can’t find anything online or ebay. I need a speaker and a microphone replacements!
Mark Peterson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 227
