Ir para o conteúdo principal
Garmin eTrex Vista H LCD screen Replacement
O que você precisa
  1. Garmin eTrex Vista H LCD screen Replacement, Removing Battery: passo 1, imagem 1 %32
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H LCD screen Replacement: passo 2, imagem 1 %32
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H LCD screen Replacement: passo 3, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 3, imagem 2 %32
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, imagem 2 %32
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H LCD screen Replacement: passo 5, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 5, imagem 2 %32 Garmin eTrex Vista H LCD screen Replacement: passo 5, imagem 3 %32
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H LCD screen Replacement: passo 6, imagem 1 %32
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H LCD screen Replacement: passo 7, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 7, imagem 2 %32
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H LCD screen Replacement, Disassembling Garmin eTrex Vista H Motherboard: passo 8, imagem 1 %32
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H LCD screen Replacement: passo 9, imagem 1 %32
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H LCD screen Replacement: passo 10, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 10, imagem 2 %32
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
    It is easy to pull the ribbon cable off, but reinserting the ribbon cable back into the wire connector is very challenging. Any tips?
    Robin Van Eyk - Responder
  11. Garmin eTrex Vista H LCD screen Replacement, LCD screen: passo 11, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement, LCD screen: passo 11, imagem 2 %32 Garmin eTrex Vista H LCD screen Replacement, LCD screen: passo 11, imagem 3 %32
    • After removing the motherboard, locate the two #1 Philips screws.
    • Carefully remove both screws.
  12. Garmin eTrex Vista H LCD screen Replacement: passo 12, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 12, imagem 2 %32
    • Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
    • Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
  13. Garmin eTrex Vista H LCD screen Replacement: passo 13, imagem 1 %32
    • Insert the new LCD screen in the device.
    Hi, Sir, i need display units for garmin etrexH, and etrex10, please let me k now the unit cost and where i can buy...thanks
    shiva raj - Responder
    Hi, I was wondering where I could get one new screen for my garmin etrex legend HCx.
    Thank you very much,
    Jordi
    Arctictern - Responder
    Hi there…Could you please help…Looking for a replacement LCD screen for a Garmin Venture Etrex? Kind regards….
    leon.visagie75@gmail.com
    Leon Visagie - Responder
Conclusão
3 outras pessoas executaram este guia.
Lauren Noyes
Membro desde: 10/17/10
248 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-30, Regan Fall 2010 Membro de Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
Membros da 3
Autoria de 5 guias
Um comentário
where can I find the LCD test
carlos gomes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 11,887
