Ir para o conteúdo principal
Garmin eTrex Vista H LCD screen Replacement
O que você precisa
  1. Garmin eTrex Vista H LCD screen Replacement, Removing Battery: passo 1, imagem 1 %32
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H LCD screen Replacement: passo 2, imagem 1 %32
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H LCD screen Replacement: passo 3, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 3, imagem 2 %32
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: passo 4, imagem 2 %32
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H LCD screen Replacement: passo 5, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 5, imagem 2 %32 Garmin eTrex Vista H LCD screen Replacement: passo 5, imagem 3 %32
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H LCD screen Replacement: passo 6, imagem 1 %32
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H LCD screen Replacement: passo 7, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 7, imagem 2 %32
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H LCD screen Replacement, Disassembling Garmin eTrex Vista H Motherboard: passo 8, imagem 1 %32
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H LCD screen Replacement: passo 9, imagem 1 %32
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H LCD screen Replacement: passo 10, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 10, imagem 2 %32
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
  11. Garmin eTrex Vista H LCD screen Replacement, LCD screen: passo 11, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement, LCD screen: passo 11, imagem 2 %32 Garmin eTrex Vista H LCD screen Replacement, LCD screen: passo 11, imagem 3 %32
    • After removing the motherboard, locate the two #1 Philips screws.
    • Carefully remove both screws.
  12. Garmin eTrex Vista H LCD screen Replacement: passo 12, imagem 1 %32 Garmin eTrex Vista H LCD screen Replacement: passo 12, imagem 2 %32
    • Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
    • Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
  13. Garmin eTrex Vista H LCD screen Replacement: passo 13, imagem 1 %32
    • Insert the new LCD screen in the device.
Conclusão
3 outras pessoas executaram este guia.
Lauren Noyes
Membro desde: 10/17/10
248 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-30, Regan Fall 2010 Membro de Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
Membros da 3
Autoria de 5 guias
Um comentário
where can I find the LCD test
carlos gomes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 11,885
