Ir para o conteúdo principal
Garmin Vivoactive HR Display Replacement
O que você precisa
  1. Garmin Vivoactive HR Display Replacement, Display: passo 1, imagem 1 %32
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: passo 2, imagem 1 %32
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
    Where can you purchase a new screen? A lot of people are having this issue.
    Joshua Clem - Responder
    Could you find one yet?
    e.g.labuschagne -
    What would be cost of replacement of Screen for Garmin Vivo -HR
    Harpreet - Responder
    how to reach the battery
    gilles PIERSON - Responder
  3. Garmin Vivoactive HR Display Replacement: passo 3, imagem 1 %32
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: passo 4, imagem 1 %32 Garmin Vivoactive HR Display Replacement: passo 4, imagem 2 %32
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
Conclusão
16 outras pessoas executaram este guia.
Chris Corry
Membro desde: 07/05/18
256 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G5, Harley Summer 2018 Membro de IUPUI, Team S2-G5, Harley Summer 2018
IUPUI-HARLEY-SU18S2G5
3 Membros
Autoria de 3 guias
19Comentários do guia
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - Responder
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - Responder
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - Responder
What type of glue i use to connect the display an the body?
culibrkboj - Responder
This one is the best way to glue display and body staying flexible and resistant to water and over a wide temperature range.:
https://fr.aliexpress.com/item/329544137...
Bruno Junca -
Dove è possibile acquistare il dispay per il vivoactive hr??
grazie per l’aiuto
Michele - Responder
Hello,
thanks for this. Where can i buy the new screen? for this
Darren Letten - Responder
Hi There
Where did you buy the display?
Regards
pearlduck -
Where i can buy the display?
pearlduck -
What’s the point of making a how to if we can’t find the parts,
Shailendra Khatri - Responder
Hi, how to change battery???
Erviajero minema - Responder
Where is the backlight located in all of this?
Sam - Responder
If only the touch part is broken, you can change only this one.  you have to heat the whole and insert a solid wire between the LCD screen and the touch part to separate them.  then clean the LCD screen and use a UV glue to glue the new touch screen.  it costs half as much as buying the whole thing.
https://fr.aliexpress.com/item/400006421...
Glue: https://fr.aliexpress.com/item/330387129...
UV light for example: https://fr.aliexpress.com/item/328080542...
Bruno Junca - Responder
Where is the backlight located in this thing? Is it built into the screen or something separate?
Sam - Responder
Hello, is the watch still water resistant, after changing the display?
Mr. GóÒdKaT - Responder
pre-owned screen from ebay, (new/never used) for £5uk.
The first instruction about entering via the top left corner is nigh on impossible unless you’re willing to damage the plastic surround which is in effect a raised bezel to protect the glass.
Since the reason for swap was a slightly cracked screen, I broke through the corner of the glass and unpeeled the shards of screen from the inner frame using heat and a scalpel to remove the adhesive. I burned through 10 minutes a few times doing this, but once the frame was clear, the replacement process was an absolute breeze.
No gasket/seal was available, so I used 1mm double-sided and followed the frame as a guide, it’s overlapped, but I’d be wary of suggesting it’s still waterproof.
Thanks for the guide, it was super helpful, and without it, I would never have attempted the repair!
Womble Messiah - Responder
I purchased my new screen through Amazon. It will take a month, or so, to get it shipped to you, as it comes from China. Received mine today and have not had chance to install it yet. but it looks good.
eaglerest - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 47
Ao todo: 26,583
