Ir para o conteúdo principal
Garmin Vivoactive HR Display Replacement
O que você precisa
  1. Garmin Vivoactive HR Display Replacement, Display: passo 1, imagem 1 %32
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: passo 2, imagem 1 %32
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
  3. Garmin Vivoactive HR Display Replacement: passo 3, imagem 1 %32
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: passo 4, imagem 1 %32 Garmin Vivoactive HR Display Replacement: passo 4, imagem 2 %32
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
Conclusão
16 outras pessoas executaram este guia.
Chris Corry
Membro desde: 07/05/18
256 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G5, Harley Summer 2018 Membro de IUPUI, Team S2-G5, Harley Summer 2018
IUPUI-HARLEY-SU18S2G5
3 Membros
Autoria de 3 guias
19 comentários
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - Responder
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - Responder
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - Responder
What type of glue i use to connect the display an the body?
culibrkboj - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 42
Ao todo: 26,569
