Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Use a Phillips #00 screwdriver to remove the four screws around the screen.
Gently pull from both ends of the casing to separate the front and back panels.
Gently unplug the white cable connector using either your fingers or tweezers.
Remove the three screws holding the motherboard in place.
To remove the ribbon cable, lift the black latch using the spudger tool.
Separate the connection using either your fingers, tweezers, or the spudger.
Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
Rotate the spudger outward until the tabs are no longer holding the screen.
When reassembling, slide the bottom of the screen under the two permanent tabs.
Push the screen out from the front.
