Ir para o conteúdo principal
Introdução
Before you begin disassembling the device, be sure the power is off.
Peças
Nenhum componente especificado.
  1. Wedge a plastic opening tool in between the outer frame and the rear panel assembly. Pry the outer frame off the perimeter of the rear panel assembly.
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly. Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Gently pull the battery cable connector from its socket on the motherboard.
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Conclusão
Andrew Burman
Membro desde: 18/01/2012
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-19, Maness Winter 2012 Membro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Membros
4 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,323
