Introdução
If you need to replace the Garmin STRIKER 4 motherboard, access it with this guide. Some reasons you may be replacing the motherboard include button sensors not working or last-resort fixes to other problems with the screen and readings. Be careful when prying away the old motherboard to avoid any further damage to the casing.
O que você precisa
Slide out the screen cable from the motherboard using the iFixit opening tool or your fingernail.
Remove the motherboard from the device.
Conclusão
