Ir para o conteúdo principal
Garmin Nuvi 680 Motherboard Replacement
O que você precisa
  1. Garmin Nuvi 680 Motherboard Replacement, Outer Case: passo 1, imagem 1 %32
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Motherboard Replacement: passo 3, imagem 1 %32
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Motherboard Replacement: passo 4, imagem 1 %32 Garmin Nuvi 680 Motherboard Replacement: passo 4, imagem 2 %32
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Motherboard Replacement: passo 6, imagem 1 %32 Garmin Nuvi 680 Motherboard Replacement: passo 6, imagem 2 %32
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Motherboard Replacement, Antenna: passo 7, imagem 1 %32 Garmin Nuvi 680 Motherboard Replacement, Antenna: passo 7, imagem 2 %32
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Garmin Nuvi 680 Motherboard Replacement, Screen Wiring: passo 8, imagem 1 %32
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Garmin Nuvi 680 Motherboard Replacement: passo 9, imagem 1 %32 Garmin Nuvi 680 Motherboard Replacement: passo 9, imagem 2 %32
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
  10. Garmin Nuvi 680 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Use a PH1 sized Philips screwdriver to remove the two screws shown.
    • These screws are 6.88 mm long
  11. Garmin Nuvi 680 Motherboard Replacement: passo 11, imagem 1 %32 Garmin Nuvi 680 Motherboard Replacement: passo 11, imagem 2 %32
    • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
    • Use a spudger to lift the edge of the motherboard.
  12. Garmin Nuvi 680 Motherboard Replacement: passo 12, imagem 1 %32
    • Gently unplug the cable for the battery
    • Gently unplug the cable for the speaker.
  13. Garmin Nuvi 680 Motherboard Replacement: passo 13, imagem 1 %32
    • Lift the motherboard out of the outer case.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Marzano
Membro desde: 01/20/11
968 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 5-22, Amido Winter 2011 Membro de Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 3,644
