Ir para o conteúdo principal
Garmin Nuvi 680 Antenna Replacement
O que você precisa
  1. Garmin Nuvi 680 Antenna Replacement, Outer Case: passo 1, imagem 1 %32
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Antenna Replacement: passo 2, imagem 1 %32
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Antenna Replacement: passo 3, imagem 1 %32
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Antenna Replacement: passo 4, imagem 1 %32 Garmin Nuvi 680 Antenna Replacement: passo 4, imagem 2 %32
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Antenna Replacement: passo 5, imagem 1 %32
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Antenna Replacement: passo 6, imagem 1 %32 Garmin Nuvi 680 Antenna Replacement: passo 6, imagem 2 %32
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Antenna Replacement, Antenna: passo 7, imagem 1 %32 Garmin Nuvi 680 Antenna Replacement, Antenna: passo 7, imagem 2 %32
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
    The antenna ribbon cable has a latch that must be lifted first. It's a light muddy brown color. It flips up and away in the opposite direction of the ribbon cable.
    ewkpates - Responder
Conclusão
Chris Marzano
Membro desde: 01/20/11
968 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 5-22, Amido Winter 2011 Membro de Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
Membros da 5
Autoria de 7 guias
Um comentário
Where can you find the replacment antenna?
All I see is external antennas on the net.
Dennis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,440
