Introdução
This guide will show you how to remove the battery from the Garmin Nuvi 65LM GPS. To remove the battery, the motherboard must also be removed after separating the front and back device casing. To put in a new battery, follow these steps in the reverse order.
O que você precisa
Place the device on a flat surface with the screen facing down.
Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
Make sure the GPS is laying on a flat surface with the open side showing.
Unscrew the four marked 4.00 mm screws with a T5 torque screwdriver
Gently lift the motherboard off of the plastic casing.
4 outras pessoas executaram este guia.
