Ir para o conteúdo principal
Garmin Nuvi 56LMT Battery Replacement
O que você precisa
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: passo 1, imagem 1 %32 Garmin Nuvi 56LMT Battery Replacement, Battery: passo 1, imagem 2 %32
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: passo 2, imagem 1 %32 Garmin Nuvi 56LMT Battery Replacement: passo 2, imagem 2 %32 Garmin Nuvi 56LMT Battery Replacement: passo 2, imagem 3 %32
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: passo 3, imagem 1 %32 Garmin Nuvi 56LMT Battery Replacement: passo 3, imagem 2 %32 Garmin Nuvi 56LMT Battery Replacement: passo 3, imagem 3 %32
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: passo 4, imagem 1 %32 Garmin Nuvi 56LMT Battery Replacement: passo 4, imagem 2 %32 Garmin Nuvi 56LMT Battery Replacement: passo 4, imagem 3 %32
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: passo 5, imagem 1 %32
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Conclusão
Equipe
USF Tampa, Team S3-G5, Nance Fall 2017 Membro de USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 417
