Ir para o conteúdo principal
Garmin Nuvi 50LM Power Button Replacement
O que você precisa
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: passo 1, imagem 1 %32 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: passo 1, imagem 2 %32
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: passo 2, imagem 1 %32 Garmin Nuvi 50LM Power Button Replacement: passo 2, imagem 2 %32
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: passo 3, imagem 1 %32 Garmin Nuvi 50LM Power Button Replacement: passo 3, imagem 2 %32
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
Conclusão
Maurice Thomas
Membro desde: 10/13/15
661 Reputação
Autoria de 5 guias
Equipe
3 comentários
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - Responder
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - Responder
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 33
Duração total: 6,808
