Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
The motherboard will now freely separate from the back casing; lay it flat next to the housing.
Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
Ferramenta utilizada nesse passo:Desoldering Pump$3.99-
De-solder the audio out port. Use a soldering iron to melt the solder on each of the leads of the port and a solder extraction tool (not shown), such as a solder sucker or copper braid.
The audio out port should now be completely separated from all other components.
Solder new, functional audio port. Make sure all solder connections are clean.
