Introdução
A faulty battery can cause the device to not power on or take a charge. Replace it.
O que você precisa
Remove the stand by pushing down on the tab and pulling the round, plastic piece away from the Garmin unit.
Plug the new battery into the same plug, with the wires going the same direction.
Test the unit by powering it on.
If it powers on stick the new battery in place with any glue or tape.
Snap the casing back together and replace the 4 screws, again with a T5 bit.
6 outras pessoas executaram este guia.
