Ir para o conteúdo principal
Garmin Nuvi 2689 LMT Battery Replacement
O que você precisa
  1. Garmin Nuvi 2689 LMT Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the stand by pushing down on the tab and pulling the round, plastic piece away from the Garmin unit.
  2. Garmin Nuvi 2689 LMT Battery Replacement: passo 2, imagem 1 %32
    • Remove the four, 4mm hex screws from the four corners of the unit.
    • This will require a T5 Screwdriver.
  3. Garmin Nuvi 2689 LMT Battery Replacement: passo 3, imagem 1 %32
    • Place the unit screen-side down flat, with the bottom facing you. There are two seams, the one on top is artificial.
    • This is the real seam, open it with a plastic opening tool in step 4.
  4. Garmin Nuvi 2689 LMT Battery Replacement: passo 4, imagem 1 %32
    • Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the tool into the unit until you feel a click.
    • Repeat this all the way around the seam.
  5. Garmin Nuvi 2689 LMT Battery Replacement: passo 5, imagem 1 %32
    • Once the seam is completely separated, you can lift the back away from the screen easily.
  6. Garmin Nuvi 2689 LMT Battery Replacement: passo 6, imagem 1 %32
    • Wedge an angled plastic prying tool under the connector at the part where the wires attach and gently pry up.
    • The battery is connected to the main circuit board via two wires, red and green in color, and is attached with a white connector. It should come free easily.
  7. Garmin Nuvi 2689 LMT Battery Replacement: passo 7, imagem 1 %32
    • The white battery is attached to the casing with an adhesive. It should be easy to pry the battery up with a prying tool.
Conclusão
Plug the new battery into the same plug, with the wires going the same direction.
Test the unit by powering it on.
If it powers on stick the new battery in place with any glue or tape.
Snap the casing back together and replace the 4 screws, again with a T5 bit.
6 outras pessoas executaram este guia.
Joseph Lingvay
Membro desde: 09/26/16
390 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 16-5, Eyestone Fall 2016 Membro de USF Tampa, Team 16-5, Eyestone Fall 2016
USFT-EYESTONE-F16S16G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 4,056
